[Geoserver-devel] [jira] Created: (GEOS-193) SVG output lacking xlink:href tag
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-193
Here is an overview of the issue:
        Key: GEOS-193
    Summary: SVG output lacking xlink:href tag
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             WMS
   Versions:
             1.2.0-rc2
   Assignee: Gabriel Roldán
   Reporter: John Stiening
    Created: Wed, 14 Jul 2004 1:56 PM
    Updated: Wed, 14 Jul 2004 1:56 PM
Environment: mac os X, geoserver rc2, postGIS, tomcat
Description:
The svg output from the WMS is not formatting points properly for me. This might be an SLD problem, since points are not showing up properly in jpeg output, but it might be more.
basically the output is:
</g>
<g id="DC:obs" class="normal">
<defs>
  <circle id='point' cx='0' cy='0' r='0.5%' fill='blue' stroke="red"/>
</defs>
<use x="-82.3" y="28.9"/>
<use x="-82.4" y="28.9"/>
<use x="-82.4" y="28.7">
What I believe it should be is:
</g>
<defs>
</defs>
<use x="-82.3" y="28.9" xlink:href="#point"/>
<use x="-82.4" y="28.9" xlink:href="#point"/>
<use x="-82.4" y="28.7" xlink:href="#point"/>
Good Luck!
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
