FeatureType cannot be created for postGIS table with single point
Key: GEOS-1941
URL: http://jira.codehaus.org/browse/GEOS-1941
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.6.2
Environment: Debian 4.0 rc2
Reporter: Milo van der Linden
Assignee: Andrea Aime
Priority: Minor
When I create a spatial table in postgis with the following:
CREATE TABLE points
gid serial NOT NULL,
point_type integer,
the_geom geometry,
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
WITHOUT OIDS;
ALTER TABLE points OWNER TO postgres;
insert into points(point_type, the_geom) values (0,SetSRID(MakePoint(50,50),4326))
I cannot create a featureType for this table because Geoserver reports:
The FeatureType 'point' has a NULL extent.
HINT: the dataset is empty or has no default geometry attribute.
