[Geoserver-devel] [jira] Created: (GEOS-1942) WMS renders point layer incorrectly
                 Key: GEOS-1942
                 URL: http://jira.codehaus.org/browse/GEOS-1942
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.4
         Environment: RHEL3, Tomcat 5.5.25. Java 1.5.0.12
            Reporter: Ryan Hofschneider
            Assignee: Andrea Aime
         Attachments: from1.6.3.pdf, from1.6.4.pdf
GeoServer 1.6.4 does not render my point layer correctly. There seems to be some type of coordinate shift occurring. My feature type info.xml is identical during my tests with 1.6.3 and 1.6.4
The details:
datastore = postgis
SRS = 4326
native bbox ~= -179.9, -72.4, 180, 88
PDF request URL:
http://localhost:8080/geoserver-1.6.4/wms?bbox=-197.89500961303665,-80.46500167846679,197.99500045776364,96.96500167846679&styles=&Format=application/pdf&request=GetMap&version=1.1.1&layers=topp:buoyobservation&width=800&height=336&srs=EPSG:4326
I am using the map preview demo page to test. The SVG link renders in FireFox as expected, but the OpenLayers and PDF links do not show a correct rendering.
I've attached two example PDFs -- one showing how the data set looks like when it is served from 1.6.3, the other when it is served up from 1.6.4.
     [ http://jira.codehaus.org/browse/GEOS-1942?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-1942:
                Key: GEOS-1942
            Project: GeoServer
         Issue Type: Bug
         Components: WMS
           Priority: Blocker
            Fix For: 1.6.5
        Attachments: from1.6.3.pdf, from1.6.4.pdf, gt2-render-2.4-SNAPSHOT.jar
The details:
datastore = postgis
SRS = 4326
PDF request URL:
