Build the list of log4j configuration files dynamically from the logs directory, currently its hardcoded
Key: GEOS-1943
URL: http://jira.codehaus.org/browse/GEOS-1943
Project: GeoServer
Issue Type: Improvement
Components: UI
Affects Versions: 1.6.4
Reporter: Gabriel Roldán
When choosing the log4j configuration file to use under server configuration, the list of files to choose from is not dynamically build but its hardcoded in {{GeoServerConfiguration.jsp}} :
{code}
<html:select property="log4jConfigFile">
<html:option value="VERBOSE_LOGGING.properties"/>
<html:option value="GEOSERVER_DEVELOPER_LOGGING.properties"/>
<html:option value="GEOTOOLS_DEVELOPER_LOGGING.properties"/>
<html:option value="DEFAULT_LOGGING.properties"/>
<html:option value="PRODUCTION_LOGGING.properties"/>
</html:select>
{code}
So there's no way of adding a custom logging configuration if not modifying one of the predefined ones.
This list should be dynamically loaded from the available .properties files in the <data_dir>/ logs directory
I'm leaving the fix version unknown as this seems to be a topic for the new UI configuration though.,
