[Geoserver-devel] [jira] Created: (GEOS-1946) Oracle 10g Error Performing SQL query (TRUE AND TRUE)
                 Key: GEOS-1946
                 URL: http://jira.codehaus.org/browse/GEOS-1946
             Project: GeoServer
          Issue Type: Bug
          Components: Oracle
    Affects Versions: 1.6.4
         Environment: gt2-oracle-spatial-2.4.3.jar, ojdbc14.jar, Mac Os X 10.5 and 10.4 ssh to Oracle 10gR2 on Debain
            Reporter: Michael Russalesi
            Assignee: Andrea Aime
            Priority: Blocker
After successfully setting up the DataStore and FeatureTypes with Oracle 10g, I ran the page:
http://localhost:8080/geoserver//wms?service=WMS&request=GetMap&format=image/png&width=800&height=600&srs=EPSG:4326&layers=topp:COUNTIES&styles=polygon&bbox=-177.1,13.71,-61.48,76.63
expecting a png with counties to appear (See full error message below).
/////excerpt/////
Error Performing SQL query: SELECT "ID", "GEOM" FROM "COUNTIES" WHERE ((TRUE AND TRUE) AND SDO_RELATE("GEOM",MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-177.24452499999998,13.605133333333335,-61.335474999999995,76.73486666666666)),'mask=anyinteract querytype=WINDOW') = 'TRUE' )
/////excerpt/////
When I run the query in SQLDeveloper without the (TRUE AND TRUE) AND statement the query executes without error. When I add the statement back, the error "Invalid relational operator" is exposed, which is identified in the log as the sqlexeption.
Why is the "(TRUE AND TRUE) AND" added to the sql statement?
The test data and setup I am using comes from the url:
http://www.oracle.com/technology/pub/articles/lokitz-spatial-geoserver.html
I have checked the oracle data, all SRID's are in order. All metadata information is in order.
/////FULL CONSOLE OUTPUT////
133342 [btpool0-4] INFO /geoserver - Loading WebApplicationContext for Spring FrameworkServlet 'dispatcher'
23 May 22:36:47 ERROR [data.jdbc] - Error Performing SQL query: SELECT "ID", "GEOM" FROM "COUNTIES" WHERE ((TRUE AND TRUE) AND SDO_RELATE("GEOM",MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-177.24452499999998,13.605133333333335,-61.335474999999995,76.73486666666666)),'mask=anyinteract querytype=WINDOW') = 'TRUE' )
java.sql.SQLException: ORA-00920: invalid relational operator
        at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
        at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:743)
        at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:207)
        at oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:790)
        at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1037)
        at oracle.jdbc.driver.T4CStatement.executeMaybeDescribe(T4CStatement.java:830)
        at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
        at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1272)
        at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
        at org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:905)
        at org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:627)
        at org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:83)
        at org.geotools.data.store.DataFeatureCollection.openIterator(DataFeatureCollection.java:241)
        at org.geotools.data.store.DataFeatureCollection.iterator(DataFeatureCollection.java:211)
        at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1585)
        at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:641)
        at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1461)
        at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1331)
        at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:310)
        at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:424)
        at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:616)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
        at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
        at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:170)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
        at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
        at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
        at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
        at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
        at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
        at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:303)
        at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
        at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:721)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
        at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
23 May 22:36:47 ERROR [geotools.rendering] - Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "ID", "GEOM" FROM "COUNTIES" WHERE ((TRUE AND TRUE) AND SDO_RELATE("GEOM",MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-177.24452499999998,13.605133333333335,-61.335474999999995,76.73486666666666)),'mask=anyinteract querytype=WINDOW') = 'TRUE' )
java.util.NoSuchElementException: Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "ID", "GEOM" FROM "COUNTIES" WHERE ((TRUE AND TRUE) AND SDO_RELATE("GEOM",MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-177.24452499999998,13.605133333333335,-61.335474999999995,76.73486666666666)),'mask=anyinteract querytype=WINDOW') = 'TRUE' )
        at org.geotools.data.store.NoContentIterator.next(NoContentIterator.java:53)
        at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1599)
Caused by: org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "ID", "GEOM" FROM "COUNTIES" WHERE ((TRUE AND TRUE) AND SDO_RELATE("GEOM",MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-177.24452499999998,13.605133333333335,-61.335474999999995,76.73486666666666)),'mask=anyinteract querytype=WINDOW') = 'TRUE' )
        at org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:916)
        ... 57 more
Caused by: java.sql.SQLException: ORA-00920: invalid relational operator
        ... 62 more
23 May 22:36:47 INFO [geoserver.filters] - Not compressing output for mimetype: image/png
