Configuration keeps reverting to namespace topp
Key: GEOS-1960
URL: http://jira.codehaus.org/browse/GEOS-1960
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.x
Reporter: Arne Kepp
Assignee: Justin Deoliveira
Priority: Blocker
Fix For: 1.7.0
(This concerns the landgate datastore and associated feature types on instance vector-unstable on Atlas)
I've added the datastore landgate and created a new namespace landgate for it. After restarting all the layers can be found as <namespace>:layername
But if you add or change a featuretype (changing cache time appears to be enough), the namespace for all featuretypes associated with this datastore reverts to "topp"
Restarting GeoServer fixes the issue.
