SRS 900913 (and others) not shown from 1.6.3 on
Key: GEOS-1961
URL: http://jira.codehaus.org/browse/GEOS-1961
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.6.4, 1.6.3, 1.7.0-beta1, 1.7.0
Environment: In my case:
Ubuntu Hardy
Tomcat 5.5
Postgres 8.3
Postgis
Reporter: Reinhard Fischer
Assignee: Andrea Aime
Instead of returning e.g. a png with a map, geoserver returns a transparent image (e.g. png) when using the srs 900913. No error message is given. However, it works fine with srs 4326.
Additionally in Version 1.6.2 of geoserver, it works with srs 900913 as well, only versions 1.6.3 and 1.7.0 alpha and 1.7.0 lates (as of today) showed this problem.
I tried:
- completely new install
- Versions 1.6.3, 1.7.0 (also latest from today)
- playing around with the queries, e.g.:
/geoserver/wms?LAYERS=namespace%3Awhatever&SRS=EPSG%3A900913&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-20037508.34,-7.081154550627918e-10,0,20037508.340000033&WIDTH=256&HEIGHT=256
worked for 1.6.2 but not for the new versions.
Other users seem to experience this problem, also with srs other than 900913. So it seems to apply to versions other than I marked above.
See
http://www.nabble.com/WMS-Calls-with-SRS-900913-not-working-in-new-version-(from-1.6.3-)-td17084331.html
http://www.nabble.com/900913-and-postgis-layer-without-a-native-srs-td17535650.html#a17535650
http://www.nabble.com/Problem-of-projection-for-data-stored-in-Oracle-Locator-td17536770.html#a17536770
