Backslash \ in PropertyIsEqualTo literal in SLD
Key: GEOS-1964
URL: http://jira.codehaus.org/browse/GEOS-1964
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.4
Environment: Servlet container: Tomcat 6.0.16.
Datastore: PostgreSQL 8.3.1 + PostGIS 1.3.3.
Reporter: Albin Lundmark
Assignee: Andrea Aime
Fix For: 1.6.5
Geoserver doesn't render my features when I use a filter like this in my SLD (see whole document below):
<ogc:Filter>
<PropertyIsEqualTo xmlns="http://www.opengis.net/ogc">
<PropertyName>USER_</PropertyName>
<Literal>TEST\allu</Literal>
</PropertyIsEqualTo>
</ogc:Filter>
The SQL generated by Geoserver returns features after I have turned on PostgreSQLs standard_compliant_strings property and tried them manually in pgAdmin. But Geoserver refuses to render them!?
The output in the log file is found below.
The SQL I'm getting works fine when I run it in pgAdmin manually. I get a resultset of 3 rows. Seems like something goes wrong afterwards that makes Geoserver unwilling to render them on the image.
Does Geoserver make another match against the literal later on in the process?
It seems like the filter never matches anything even though I see rows
in the PostGIS having the field USER_ set to TEST\allu. I can see in
the geoserver log that the SQL is built correctly and returns features
when I try it in PostGIS manually, but in a WMS request it never
results in any points on the map.If I remove the filter or change the PropertyName and Literal to a
field and value without backslash it works!The SLD document is validating and looks like this:
<StyledLayerDescriptor xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns="http://www.opengis.net/sld"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<NamedLayer>
<Name>sydbs:TEST_PT</Name>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<ogc:Filter>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<WellKnownName>circle</WellKnownName>
<Fill>
<CssParameter
name="fill">#FF0000</CssParameter>
</Fill>
<Stroke>
<CssParameter
name="stroke">#000000</CssParameter>
</Stroke>
</Mark>
<Size>5</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
The output from the log file is:
2008-05-28 15:33:12,325 DEBUG [org.geotools.rendering] - processing 1 stylers for TEST_PT
2008-05-28 15:33:12,325 DEBUG [org.geotools.rendering] - creating rules for scale denominator - 7 142,857
2008-05-28 15:33:12,325 DEBUG [org.geotools.rendering] - Expanding rendering area by 5 pixels to consider stroke width
2008-05-28 15:33:12,325 DEBUG [org.geotools.rendering] - Querying layer TEST_PT with bbox: ReferencedEnvelope[1440618.0 : 1441638.0, 6302315.0 : 6303335.0]
2008-05-28 15:33:12,325 DEBUG [org.geotools.data.jdbc] - calling sql builder with filter [[Filter.INCLUDE AND Filter.INCLUDE] AND [[ geom bbox POLYGON ((1440618 6302315, 1440618 6303335, 1441638 6303335, 1441638 6302315, 1440618 6302315)) ] AND [ USER_ = TEST\allu ]]]
2008-05-28 15:33:12,325 TRACE [org.geotools.core] - ENTRY 2
2008-05-28 15:33:12,325 TRACE [org.geotools.core] - ENTRY 12 345
2008-05-28 15:33:12,325 TRACE [org.geotools.core] - ENTRY 4
2008-05-28 15:33:12,325 TRACE [org.geotools.core] - ENTRY 14
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - exporting LogicFilter
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - exporting GeometryFilter
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - exporting ExpressionAttribute
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - exporting LiteralExpression
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - exporting SQL ComparisonFilter
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - Filter type id is 14
2008-05-28 15:33:12,325 DEBUG [org.geotools.filter] - Filter type text is =
2008-05-28 15:33:12,325 DEBUG [org.geotools.data.jdbc] - sql is SELECT "oid", "USER_", encode(asBinary(force_2d("geom"),'XDR'),'base64') FROM "business"."TEST_PT" WHERE ((TRUE AND TRUE) AND ("geom" && GeometryFromText('POLYGON ((1440618 6302315, 1440618 6303335, 1441638 6303335, 1441638 6302315, 1440618 6302315))', 2400) AND "USER_" = 'TEST\allu'))
2008-05-28 15:33:12,325 DEBUG [org.geotools.data.jdbc] - SELECT "oid", "USER_", encode(asBinary(force_2d("geom"),'XDR'),'base64') FROM "business"."TEST_PT" WHERE ((TRUE AND TRUE) AND ("geom" && GeometryFromText('POLYGON ((1440618 6302315, 1440618 6303335, 1441638 6303335, 1441638 6302315, 1440618 6302315))', 2400) AND "USER_" = 'TEST\allu'))
2008-05-28 15:33:12,325 DEBUG [org.geotools.data.jdbc] - About to execute query: SELECT "oid", "USER_", encode(asBinary(force_2d("geom"),'XDR'),'base64') FROM "business"."TEST_PT" WHERE ((TRUE AND TRUE) AND ("geom" && GeometryFromText('POLYGON ((1440618 6302315, 1440618 6303335, 1441638 6303335, 1441638 6302315, 1440618 6302315))', 2400) AND "USER_" = 'TEST\allu'))
2008-05-28 15:33:12,340 DEBUG [org.geotools.rendering] - Style cache hit ratio: NaN , hits 0, requests 0
