[Geoserver-devel] [jira] Created: (GEOS-1976) Regression, cannot configure layer groups without explicit styles anymore
                 Key: GEOS-1976
                 URL: http://jira.codehaus.org/browse/GEOS-1976
             Project: GeoServer
          Issue Type: Bug
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 1.7.0-beta1
The WMS layer groups panel allowed the user more style specification options:
* specify all styles explicitly (like the release config on trunk does now)
* do not specify anything and have default styles be used (like the configuration on 1.6.x is doing)
* specify a comma separated list but omit some of them (e.g.: population,polygon)
The second and third options do not work anymore on trunk. The following exception is thrown in the second case:
{code}
008-06-09 18:27:06.413::WARN: /geoserver/admin/saveToGeoServer.do
java.lang.RuntimeException: No such style:
  at org.vfny.geoserver.global.WMS.setBaseMapStyles(WMS.java:500)
  at org.vfny.geoserver.global.WMS.load(WMS.java:224)
  at org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:80)
  at org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:170)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
{code}
