[Geoserver-devel] [jira] Created: (GEOS-1988) RESTConfig does not compile with new configuration API
                 Key: GEOS-1988
                 URL: http://jira.codehaus.org/browse/GEOS-1988
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.x
            Reporter: David Winslow
            Assignee: David Winslow
            Priority: Minor
Since the recent configuration system upgrade, RESTConfig's hooks into the configuration system are borked. Revise and fix, should be fairly straightforward.
