rest/styles throws Exception on 1.6.x
Key: GEOS-1992
URL: http://jira.codehaus.org/browse/GEOS-1992
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.6.4
Reporter: Andrea Aime
Assignee: David Winslow
Fix For: 1.6.5
Hi David,
hittting http://localhost:8080/geoserver/rest/styles on 1.6.x gives me the followin stack trace:
{code}
Expression page is undefined on line 6, column 18 in HTMLTemplates/styles.ftl.
The problematic instruction:
==> ${page.currentURL} [on line 6, column 16 in HTMLTemplates/styles.ftl]
Java backtrace for programmers:
freemarker.core.InvalidReferenceException: Expression page is undefined on line 6, column 18 in HTMLTemplates/styles.ftl.
at freemarker.core.TemplateObject.assertNonNull(TemplateObject.java:124)
at freemarker.core.TemplateObject.invalidTypeException(TemplateObject.java:134)
at freemarker.core.Dot._getAsTemplateModel(Dot.java:78)
at freemarker.core.Expression.getAsTemplateModel(Expression.java:89)
at freemarker.core.Expression.getStringValue(Expression.java:93)
at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
at freemarker.core.Environment.visit(Environment.java:208)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
{code}
It's not critical, but wondering if it may be an issue on trunk as well. I'm not using the "release" configuration,
but the error does not seem config related. Well, let me know
