Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-2
Here is an overview of the issue:
Key: GEOS-2
Summary: Service Exception text should be encoded properly into XML
Type: Bug
Status: Unassigned
Priority: Major
Original Estimate: 7 minutes
Time Spent: Unknown
Remaining: 7 minutes
Project: GeoServer
Components:
Error Reporting
Fix Fors:
wms-merge
Versions:
wms-merge
Assignee:
Reporter: Chris Holmes
Created: Tue, 18 Nov 2003 2:04 PM
Updated: Tue, 18 Nov 2003 2:04 PM
Description:
Occasionally an error message will contain something like <Query>, with angled brakets. If this is reported directly to the client, then it is parsed as an xml element. Therefor it should be encoded with xml escape characters, to <, or whatever it is. There is code to help this, was in GMLBuilder, should move to its own class
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
