[Geoserver-devel] [jira] Created: (GEOS-2001) WellKnownNames aren't right in SLD
                 Key: GEOS-2001
                 URL: http://jira.codehaus.org/browse/GEOS-2001
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.3
         Environment: Windows 2003 Server 32Bit; 16GB RAM; 8-core system; ArcSDE Backend
            Reporter: Albrecht Weiser
            Assignee: Andrea Aime
            Priority: Minor
The WellKnownNames-rendering of geoserver seems to be wrong: square renders a square; circle - square; triangle - triangle; star - square; cross - circle; x - x. Assuming that a square is the default geometry and star and cross aren't implemented since 1.6.3, the circle at the cross-definition seems to be at the wrong place.
