[Geoserver-devel] [jira] Created: (GEOS-2008) The links available in the mini-map preview of the featuretypes are not correct
                 Key: GEOS-2008
                 URL: http://jira.codehaus.org/browse/GEOS-2008
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 1.6.4
         Environment: The bug is existing as well in the 1.6.5 nightly distribution
            Reporter: Sylvain Caillot
            Assignee: Andrea Aime
In the mini map preview interface (mapPreview.do) available in GeoServer, the links for the different outputs views contain systematically /geoserver/WEB-INF/pages/..? while it should be geoserver/...?
Examples:
http://localhost:8080/figis/geoserver/WEB-INF/pages/wms?bbox=-
It should be: http://localhost:8080/figis/geoserver/wms?bbox=-
