[Geoserver-devel] [jira] Created: (GEOS-2009) geoserver fails to remmber reprojection when restarting
                 Key: GEOS-2009
                 URL: http://jira.codehaus.org/browse/GEOS-2009
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS
    Affects Versions: 1.7.0-beta1
         Environment: debian lenny/testing using the sun-java package.
            Reporter: Ivan Willig
            Assignee: Andrea Aime
I found what i think is a bug in 1.7.0 beta 1. this bug involves re-projecting postgis data, i have search codehaus and did not find it. however i wanted to ask the channel before i opened an issue. here is the bug: I have some postgis information which has a native srs of 26919. I have reprojected it to 4326 so i can use geowebcache. everything works fine, except when i restart geoserver, geoserver "forgets" that it needs to reproject the information. so my question is, should i open an issue ?
