[Geoserver-devel] [jira] Created: (GEOS-2014) Regionating should work without GWC
                 Key: GEOS-2014
                 URL: http://jira.codehaus.org/browse/GEOS-2014
             Project: GeoServer
          Issue Type: Improvement
            Reporter: David Winslow
            Assignee: Andrea Aime
Currently GeoWebCache is a critical dependency for auto-regionated KML; it is required to generate the KML documents with the network links and level-of-detail settings that actually load the tiles generated by GeoServer WMS. It would be great to have this work "on its own" with GeoServer's KML reflector generating the parent documents.
     [ http://jira.codehaus.org/browse/GEOS-2014?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
David Winslow reopened GEOS-2014:
David, don't forget to port this (r10050) to trunk.
                Key: GEOS-2014
            Project: GeoServer
           Assignee: David Winslow
            Fix For: 1.7.0
