[Geoserver-devel] [jira] Created: (GEOS-2016) java.lang.NullPointerException on GeoTiff CoverageStore Creation
                 Key: GEOS-2016
                 URL: http://jira.codehaus.org/browse/GEOS-2016
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.3
         Environment: Fedora 9, Red Hat 5, jdk1.6.0_06
            Reporter: Aaron Sutula
            Assignee: Andrea Aime
         Attachments: gs_stack_trace.log
I used gdal to convert some GRIB data to a multi-band GeoTiff (each band represents a time step). The image has 7 bands with no color tables. When attempting to load the GeoTiff into Geoserver as a new CoverageStore, I get java.lang.NullPointerException. Other gdal-based software can read the file fine. So can qgis. Stack stace attached.
