Reprojecting data coming from Oracle generate layout problems
Key: GEOS-2017
URL: http://jira.codehaus.org/browse/GEOS-2017
Project: GeoServer
Issue Type: Bug
Components: Oracle
Affects Versions: 1.6.4
Environment: Affect current 1.6.5 nightly version
Reporter: Sylvain Caillot
Assignee: Andrea Aime
Attachments: projection_prob.doc, shapefiles.zip
When reprojecting GIS data coming from an Oracle data, there are some problems drawing the vector representations.
It is not systematic and may disappear by zooming in and out.
The attached word file shows the difference between 2 maps based on Oracle and on shapefile.
The shapefile which has been loaded into Oracle using Mapbuilder and then displyed using GeoServer is also attached.
