SLD Inline Feature Request doesn't work in a JUnit test
Key: GEOS-2019
URL: http://jira.codehaus.org/browse/GEOS-2019
Project: GeoServer
Issue Type: Test
Components: WMS
Affects Versions: 1.7.0-beta1
Reporter: David Winslow
Assignee: Justin Deoliveira
Attachments: SLDWithInlineFeature.xml, SLDWithInlineFeatureTest.java
The attached JUnit test gets an empty response in the testing environment. If I run GeoServer normally and use
curl -T SLDWithInlineFeature.xml -XPOST http://localhost:8080/geoserver/ows | display -
I get the expected JPEG image, so something is not being properly mocked up for tests. I've been banging my head against this one for a while so I'm going to move on to something else, but ticket the issue so we don't forget about it.
Assigning to Justin as I suspect this is in his area of expertise.
