[Geoserver-devel] [jira] Created: (GEOS-2028) KVP parser uses Filter 1.0 parser configuration instead of 1.1
                 Key: GEOS-2028
                 URL: http://jira.codehaus.org/browse/GEOS-2028
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.6.4
            Reporter: Gabriel Roldán
            Assignee: Andrea Aime
             Fix For: 1.6.5
If GeoServer supports WFS 1.1 then it should support the filters used in a GetFeature request to be 1.1 filters, not only 1.0 ones.
Yet, the {{FilterKvpParser}} uses the {{org.geotools.filter.v1_0.OGCConfiguration}} configuration for the parser, failing with filters encoded in 1.1.
[Sample request|http://localhost:8080/geoserver/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=topp:states&PROPERTYNAME=the_geom&SRSNAME=EPSG:4326&filter=&lt;ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;ogc:Intersects&gt;&lt;ogc:PropertyName&gt;the\_geom&lt;/ogc:PropertyName&gt;&lt;gml:Polygon&gt;&lt;gml:exterior&gt;&lt;gml:LinearRing&gt;&lt;gml:posList&gt;\-112\.6881725003984 46.21546542390438 -109.77324582151394 46.21546542390438 -109.77324582151394 47.59622016653386 -112.6881725003984 47.59622016653386 -112.6881725003984 46.21546542390438</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></ogc:Intersects></ogc:Filter>]
Produces the following exception:
{code}
org.xml.sax.SAXException: Attempted to construct illegal filter - I dont understand the tag: gml:exterior. HINT: tags are case-sensitive!
{code}
Simply changing the configuration to {{org.geotools.filter.v1_1.OGCConfiguration}} fixes the issue for this particular case, though I'm not sure if it'll work for all cases.
May be when the request is a 1.0 one we should use the 1.0 parser and when the request version is 1.1 the filter 1.1 configuration?
     [ http://jira.codehaus.org/browse/GEOS-2028?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Gabriel Roldán reopened GEOS-2028:
                Key: GEOS-2028
            Project: GeoServer
         Issue Type: Bug
         Components: WFS
            Fix For: 1.6.5, 1.7.0-RC1
Sample request
{code}
{code}
{code}
{code}
Andrea Aime reopened GEOS-2028:
See http://jira.codehaus.org/browse/GEOS-2559
                Key: GEOS-2028
            Project: GeoServer
         Issue Type: Bug
         Components: WFS
Sample request
{code}
{code}
{code}
{code}
