[Geoserver-devel] [jira] Created: (GEOS-2041) Community schemas bindings for GML._Curve and GML._Geometry do not support client properties
                 Key: GEOS-2041
                 URL: http://jira.codehaus.org/browse/GEOS-2041
             Project: GeoServer
          Issue Type: Bug
          Components: Community schema
    Affects Versions: 1.6.x
            Reporter: Ben Caradoc-Davies
            Assignee: Ben Caradoc-Davies
             Fix For: 1.6.x
The community schemas binding overrides for GML._Curve and GML._Geometry convert geometric attributes into their geometry value objects, but ignore requests for client properties set in the mapping file. This causes client properties to not be encoded. When geometry data is present, this is typically not a problem, but it precludes specification-conformant encoding of missing data. For example, in GeoSciML v2, a missing value of of gsml:Borehole/sa:shape should be encoded as <sa:shape xlink:href="urn:ogc:def:nil:OGC:missing"/>. Users would like to set this href in the mapping file, but it is ignored.
