[Geoserver-devel] [jira] Created: (GEOS-2044) Can't add GeoTIFF coverage if it has exactly one overview
                 Key: GEOS-2044
                 URL: http://jira.codehaus.org/browse/GEOS-2044
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
    Affects Versions: 1.6.4
         Environment: RHEL 3, Java 1.5.0_12, JBoss 4.0.3SP1, GeoServer 1.6.4
            Reporter: Ryan Hofschneider
            Assignee: Andrea Aime
Can't add GeoTIFF coverage if it has exactly one overview -- a NullPointerException is thrown when you try to add it using the GeoServer UI. I've identified the problem code in GeoTools; see: http://jira.codehaus.org/browse/GEOT-1925
