[Geoserver-devel] [jira] Created: (GEOS-2065) Test passing by accident on the new WFS 1.1 test suite
                 Key: GEOS-2065
                 URL: http://jira.codehaus.org/browse/GEOS-2065
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.7.0-beta1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Critical
             Fix For: 1.7.0
The test wfs:wfs-1.1.0-Basic-GetFeature-tc14.1 states:
{panel}
The geometry representations in the response must correspond to the CRS specified in the @srsName attribute, or the service default if not specified or unknown. Use values as recommended in OGC 06-023 (e.g. 'urn:x-ogc:def:crs:EPSG:6.10.2:4326').
{panel}
and the request is:
{code:xml}
<wfs:GetFeature xmlns="http://www.occamlab.com/ctl&quot; xmlns:xi="http://www.w3.org/2001/XInclude&quot;
                xmlns:ctl="http://www.occamlab.com/ctl&quot;
                xmlns:saxon="http://saxon.sf.net/&quot;
                xmlns:parsers="http://www.occamlab.com/te/parsers&quot;
                xmlns:te="java:com.occamlab.te.TECore"
                xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot;
                xmlns:ogc="http://www.opengis.net/ogc&quot;
                xmlns:wfs="http://www.opengis.net/wfs&quot;
                xmlns:p="http://teamengine.sourceforge.net/parsers&quot;
                xmlns:ows="http://www.opengis.net/ows&quot;
                xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;
                xmlns:xlink="http://www.w3.org/1999/xlink&quot;
                xmlns:gml="http://www.opengis.net/gml&quot;
                xmlns:myparsers="http://teamengine.sourceforge.net/parsers&quot;
                xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
                service="WFS"
                version="1.1.0">
         <wfs:Query srsName="urn:x-ogc:def:crs:EPSG:4326" typeName="sf:PrimitiveGeoFeature"/>
      </wfs:GetFeature>
{code}
When the patches for GEOS-2064 are applied, this test stops passing because we end up answering
wit urn:x-ogc:def:crs:EPSG:6.11.2:4326 instead of using urn:x-ogc:def:crs:EPSG:4326.
If the CITE really means we have to answer with the same exact urn used in the request, we're not compliant
even without the patches, the test just passes because our hard coded answer matches the test expectation,
for example, if the test used the suggested value 'urn:x-ogc:def:crs:EPSG:6.10.2:4326' we would not pass it
either way.
The test is in my opinion broken, as it cannot expect the server to respond with the same verbatim urn,
but just by an equivalent one. Failing a fix for the test, we could work around by providing a context value
to the encoder that specifies the expected srs encoding, or enable, just when the cite hacks are on, a
simple text post processing filter that replaces all occurrences of our urn encoding with the one used
in the request (should they differ). The latter really qualifies as a "cite hack" :wink:
