Fix WFS 1.1 xlink failures
Key: GEOS-2068
URL: http://jira.codehaus.org/browse/GEOS-2068
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.0-beta1
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.7.0
Besides the urn encoding related issues I've found 3 failing tests:
{panel}
wfs:GetGmlObject-POST-XML-1
wfs:GetGmlObject-POST-XML-2
wfs:GetGmlObject-POST-XML-3
{panel}
which all fail with the following service exception:
{code:xml}
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.RuntimeException: No response: ( object = class org.geotools.jdbc.JDBCDataStore, outputFormat = GML3 )
No response: ( object = class org.geotools.jdbc.JDBCDataStore, outputFormat = GML3 )</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
{code}
Hmm... it seems the wrong object is returned by the wfs service object?
