[Geoserver-devel] [jira] Created: (GEOS-2080) Set default value for datastore namespace from the "folder" the datastore is being set up into
                 Key: GEOS-2080
                 URL: http://jira.codehaus.org/browse/GEOS-2080
             Project: GeoServer
          Issue Type: Improvement
          Components: Wicket UI
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0
In Data Manager, for the time being folders are namespace prefixes.
DataStoreFactories have a namespace parameter used by convention, there's nothing really mandatory in the geotools data api that forces a datastore to accept a "namespace" parameter. Yet, that has been the common practice since geoserver required feature types to be in a namespace configurable by the user.
So in order to reach feature parity with the old UI, we'll have to match the namespace parameter when setting up a new datastore and assign it the namespace uri from the "folder" (ie, namespace prefix) the datastore is being set up into
