[Geoserver-devel] [jira] Created: (GEOS-2093) Split up server admin tabs into pages
                 Key: GEOS-2093
                 URL: http://jira.codehaus.org/browse/GEOS-2093
             Project: GeoServer
          Issue Type: Task
    Affects Versions: 2.0-alpha1
         Environment: All - platform independent
            Reporter: Chris Patterson
            Assignee: David Winslow
            Priority: Minor
Break up the admin tabs into separate pages and add links to them in the sidebar, as discussed.
As part of this change, can we also rename "Persistence" to "Status"? In light of GEOS-2091 it seems silly to continue using that title.
