[Geoserver-devel] [jira] Created: (GEOS-2125) Exception on changing LayerGroup Configuration
                 Key: GEOS-2125
                 URL: http://jira.codehaus.org/browse/GEOS-2125
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.x
            Reporter: David Winslow
            Assignee: Andrea Aime
             Fix For: 1.7.0-RC1
Steps to reproduce:
1. Start with an unmodified copy of the release data.
2. Log in and add a layergroup. (I was able to trigger this bug by setting one up with the following params:
name=thebestlayerever
layers=topp:states,sf:streams
styles=
bbox=autogenerated
3. Submit, Apply, Save.
4. There is no 4, you should have a stack trace by now.
