[Geoserver-devel] [jira] Created: (GEOS-2136) StatusPage
StatusPage
                 Key: GEOS-2136
                 URL: http://jira.codehaus.org/browse/GEOS-2136
             Project: GeoServer
          Issue Type: Sub-task
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0.x
Shows the following status of the geoserver application:
- Locks (allows to release locks) *this option should be removed as its not currently possible to do so, see GEOS-2130*
- Connections
- JVM Memory Usage (allows to run the garbage collector)
- JVM Version
- JAI Availability
- JAI Maximum Memory
- JAI Memory Usage
- JAI Memory Threshold
- Number of JAI Tile Threads
- JAI Tile Thread Priority
- Update Sequence
- Configuration status bar
- TimeStamps
-- GeoServer
-- Configuration
-- XML
