[Geoserver-devel] [jira] Created: (GEOS-2137) ContactInformationPage
                 Key: GEOS-2137
                 URL: http://jira.codehaus.org/browse/GEOS-2137
             Project: GeoServer
          Issue Type: Sub-task
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0.x
ContactInformationPage allows to set a server wide contact info so it propagates to the plugged services contact info in their respective capabilities documents
