GlobalSettingsPage
Key: GEOS-2138
URL: http://jira.codehaus.org/browse/GEOS-2138
Project: GeoServer
Issue Type: Sub-task
Components: Wicket UI
Affects Versions: 2.0-alpha1
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.0.x
Application wide settings
- verbose xml output: whether xml responses should use pretty printing or not, just a hint
- verbose exceptions: whether exception reports shall include as much information as possible
- number of decimals: hint for the preferred number of decimals to use in decimal numbers in xml output. May be overridden by service specific configuration.
- maximum number of features: limit on the number of features to return (applies to WFS GetFeature, WMS, and wherever else may apply). May be overridden by service specific configuration.
- Character set: charset to use in xml and perhaps other text based responses (html, txt, ...)
- Proxy base url: Sets an alternate base url for ogc responses, so it can be in line with a configured proxy.
- Log to std out: whether to log to stdout as well as to the geosever.log file or not
- Log location: where to store the logs file
