[Geoserver-devel] [jira] Created: (GEOS-2156) DataStoreConfiguration
                 Key: GEOS-2156
                 URL: http://jira.codehaus.org/browse/GEOS-2156
             Project: GeoServer
          Issue Type: Sub-task
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0.x
Allows to set up a DataStore based on its configuration parameters
- Enabled
- Namespace
- List of datastore parameters dynamically generated based on the {{DataAccessFactory.Param}} it expects
     [ http://jira.codehaus.org/browse/GEOS-2156?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-2156:
DataStore Configuration
                Key: GEOS-2156
            Project: GeoServer
            Fix For: 2.0.x
- (/) Data Source name
- (/) Enabled
- (/) Namespace
- (/) List of datastore parameters dynamically generated based on the {{DataAccessFactory.Param}} it expects
