[Geoserver-devel] [jira] Created: (GEOS-2159) New KML Reflector does not validate the number of filters in the request matches the number of layers in the request
                 Key: GEOS-2159
                 URL: http://jira.codehaus.org/browse/GEOS-2159
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.4
            Reporter: Matt Bucknam
            Assignee: Andrea Aime
The new KML Reflector (/wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLReflector.java) does not validate the request contains the same number of filters as it does layers like the old one did (/wms/src/main/java/org/vfny/geoserver/wms/servlets/KMLReflector.java)
This causes an array index out of bound exception instead of the more descriptive error message given in the old one.
I would like to put these checks as well as some other request parameter checks in the new reflector and bail early if they fail with a descriptive message. I can submit a patch if it sounds like a good solution.
