[Geoserver-devel] [jira] Created: (GEOS-2164) DataStoreConfiguration page fails if going to edit a datastore when the propper geotools plugin is not available
                 Key: GEOS-2164
                 URL: http://jira.codehaus.org/browse/GEOS-2164
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0.x
If a configuration is loaded that has a datastore configured, but the geotools plugin for the datastore kind is no longer available, editing the datastore fails with an exception instead of providing a useful feedback message:
java.lang.IllegalArgumentException: Can't get the DataStoreFactory for the given connection parameters
     at org.geoserver.web.data.datastore.DataStoreConfiguration.<init>(DataStoreConfiguration.java:100)
