Removing layers part of a base layer group causes exception
Key: GEOS-2167
URL: http://jira.codehaus.org/browse/GEOS-2167
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.0-RC1, 1.6.4
Reporter: Andrea Aime
Assignee: Andrea Aime
Priority: Critical
Fix For: 1.6.5, 1.7.0-RC2
Removing a layer that's part of a base group and then trying to save resutls in the following exception:
{code}
java.lang.RuntimeException: No such layer: streams
at org.vfny.geoserver.global.WMS.setBaseMapLayers(WMS.java:464)
at org.vfny.geoserver.global.WMS.load(WMS.java:226)
at org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:80)
at org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
{code}
The UI should prevent the removal of the feature type. This is probably something happening on 1.6.x as well.
