Layers in the default namespace must be qualified (the ones in the other namespace do not?)
Key: GEOS-2181
URL: http://jira.codehaus.org/browse/GEOS-2181
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.0-RC1
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.7.0-RC2
Looking into GEOS-2126 I've set up three layers with the same name, and different namespace:
- topp:states (usual shapefile)
- cite:states (same shapefile as above, different namespace)
- sde:states (shapefile exported to postgis, one column removed to make sure the feature type was not the same)
Now, the two following three requests do work fine:
{code}
<DescribeFeatureType
version="1.0.0" service="WFS"
xmlns="http://www.opengis.net/wfs"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<TypeName>sde:states</TypeName>
</DescribeFeatureType>
<TypeName>cite:states</TypeName>
<TypeName>states</TypeName>
{code}
Note that none declares the prefix, but all return the proper result. What's a bit shocking is that the following one breaks:
{code}
<TypeName>topp:states</TypeName>
resulting in:
{code}
"java.lang.RuntimeException: Parsing failed for TypeName: java.lang.IllegalArgumentException: prefix topp is not bound to a namespace
prefix topp is not bound to a namespace"
{code}
This happens only with xml requests. It seems the topp schema is bound with the "" prefix but not with the "topp" prefix?
