Problem with KML when using in OpenLayers
Key: GEOS-2186
URL: http://jira.codehaus.org/browse/GEOS-2186
Project: GeoServer
Issue Type: Bug
Components: Google Earth KML Output
Affects Versions: 1.6.2
Environment: Debian, Glassfish
Reporter: Laurent Pierre
Assignee: Andrea Aime
Attachments: agences.kml
I try to use KML produced by Geoserver (1.6.4) in OpenLayers (2.6) but the XML generated is not accepted (silently alas). I checked the file and I eventually found 2 'mistakes' in the KML. Here's 2 fragments where the first (corrected) works while the second (directly from Geoserver) fails :
<kml xmlns="http://earth.google.com/kml/2.2">
<Document>
<name>edfgeo:clientassoc</name>
<Style id="GeoServerStyleclientassoc.nfm--730056c2_11c0891a30b_-21f4">
<IconStyle>
<color>ff33ffff</color>
<colorMode>normal</colorMode>
<Icon>
<href>http://maps.google.com/mapfiles/kml/pal4/icon25.png</href>
</Icon>
</IconStyle>
and
<kml >
<Document>
<IconStyle>
<Icon/>
</IconStyle>
<IconStyle>
<Icon>
</Icon>
</IconStyle>
In the second fragment the default namespace is missing and a 'void' IconStyle appears.
The style provided seems irrelevant and I made several tests with different generated KML.
