Placemark points are outside of sufficiently concave geometries.
Key: GEOS-2189
URL: http://jira.codehaus.org/browse/GEOS-2189
Project: GeoServer
Issue Type: Improvement
Components: Google Earth KML Output
Reporter: David Winslow
Assignee: David Winslow
Since we just use the simple centroid of polygons to position the point used for labelling KML placemarks, if a polygon has a hole in the center or simply is particularly curved, placemark labels will end up outside of the polygon. The GeoTools renderer seems to avoid this problem, so it may be a good place to look for techniques to avoid this.
