URLs are not properly encoded (UTF-8)
Key: GEOS-2205
URL: http://jira.codehaus.org/browse/GEOS-2205
Project: GeoServer
Issue Type: Bug
Components: CITE
Affects Versions: 1.6.4
Environment: Windows Vista (but presumably all)
Reporter: Mike Pumphrey
Assignee: Andrea Aime
Priority: Blocker
Fix For: 1.6.5
While running the WFS 1.1 CITE test, the sf:EntitéGénérique FeatureType does not create/display properly.
This is the current OpenLayers output:
http://atlas.openplans.org:8080/geoserver-1.6.5-cite/wms?bbox=-1.125,33.55,23.625,65.45&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=sf:EntitéGénérique&width=477&height=550&srs=EPSG:4326
Which results in a WMS error:
<ServiceExceptionReport version="1.1.1" >
<ServiceException code="LayerNotDefined">
Could not find layer sf:Entit??G??n??rique
</ServiceException>
</ServiceExceptionReport>
This should be the output:
http://atlas.openplans.org:8080/geoserver-1.6.5-cite/wms?bbox=-1.125,33.55,23.625,65.45&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=sf%3AEntit�G�n�rique&width=477&height=550&srs=EPSG:4326
[ http://jira.codehaus.org/browse/GEOS-2205?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-2205:
The title is misleading, the issue here is that the preview page is not properly url encoding the type name in the generated link, this has nothing to do with the locale
Key: GEOS-2205
Project: GeoServer
Issue Type: Bug
Components: CITE
Priority: Blocker
Fix For: 1.6.5
</ServiceException>
