Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-221
Here is an overview of the issue:
Key: GEOS-221
Summary: adding shapefile fetature type problem
Type: Bug
Status: Open
Priority: Major
Original Estimate: 1 hour
Time Spent: Unknown
Remaining: 1 hour
Project: GeoServer
Components:
Struts
Fix Fors:
1.2.3
Versions:
1.2.2
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Thu, 7 Oct 2004 5:24 PM
Updated: Thu, 7 Oct 2004 5:24 PM
Description:
I have setup Geoserver 1.2.2. under Windows.
The demo works fine.
I added a shapefile datastore through the web interface.
Then I add a new feature type to it. I created a folder
in the featuretypes folder and added the shapefiles to it.
It seems to work when I saved it but checking it I see
the folder name has changed: the name of the shapefile
is added to it and the shapefiles it contained are
gone. It does have an info.xml file.
Does this happen when you change one of the properties
of the featuretype and it is a wrong one?
Help is much appreciated.
Henk Laloli
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
