unfilled polygons with pdf output
Key: GEOS-2213
URL: http://jira.codehaus.org/browse/GEOS-2213
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.6.4
Environment: Red Hat Linux, Apache Tomact 5.5.25, Java 1.6
Reporter: Stefan Ziegler
Assignee: Andrea Aime
Attachments: samples.zip
Polygons are sometimes not filled with the raster image assigned in the SLD with parameters transparent=true and format=application/pdf. It never happens with setting transparent=false. The same polygon is filled by changing the bounding box.
Sample requests:
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=Schutzzonen_und_areale&TRANSPARENT=false&BBOX=605213.0567847588,230073.70477368,606279.6292054513,230887.29808434&WIDTH=8600&HEIGHT=6560&SRS=EPSG:21781
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=Schutzzonen_und_areale&TRANSPARENT=true&BBOX=605213.0567847588,230073.70477368,606279.6292054513,230887.29808434&WIDTH=8600&HEIGHT=6560&SRS=EPSG:21781
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=Schutzzonen_und_areale&TRANSPARENT=true&BBOX=605437.350144766,230116.32297205,605650.4726458739,230278.89518739&WIDTH=8600&HEIGHT=6560&SRS=EPSG:21781
Attached:
SLD-file
Shapes with sample data
raster image
