PropertyFileWatcher overzealously checks for file changes limiting scalability
Key: GEOS-2216
URL: http://jira.codehaus.org/browse/GEOS-2216
Project: GeoServer
Issue Type: Improvement
Affects Versions: 1.7.0-RC2
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.7.1
During benchmarks or high load situations (tile cache seeding) GeoServer can churn out something like 50 requests per second, there is no need to check the last modified date of the security files that often. Limit the check rate to once per second, it's more than enough.
