OWSUtils application generates sizeable amount of heap garbage
Key: GEOS-2221
URL: http://jira.codehaus.org/browse/GEOS-2221
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.0-RC2
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.7.0-RC3
A WMS memory profiling sessions showed that OWSUtils class, called very often by the dispatcher, generates a very sizeable amount of garbage, second only to the very BufferedImages allocated to draw the images. The memory profiler showed somethign along the line of 18MB of buffered images, and 14MB of Method and StringBuilder objects coming out of OWSUtils.
I've reworked OWSUtils into a cacheable structure that avoids most allocations and lookups, and that solves GEOS-749 and GEOS-2218 as well. Given it makes quite a difference in benchmarks I'm developing for FOSS4G, is it ok to commit it right away?
I can add some testing as well (OWSUtils has none, at least not directly)
