[Geoserver-devel] [jira] Created: (GEOS-2233) CoverageInfo getGridCoverage methods should make use of the requested raster dimensions
                 Key: GEOS-2233
                 URL: http://jira.codehaus.org/browse/GEOS-2233
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.1, 1.7.0 , 1.7.0-RC3, 1.7.x, 2.0.x
            Reporter: Simone Giannecchini
            Assignee: Andrea Aime
CoverageInfo getGridCoverage methods should allow to set not only the requested envelope but also the requested raster dimensions in order to allow subsampling otherwise, depending on the source implementation (namely, if deferrred loading is not implemented) OOM errors would be generated quite easily even for simple FeatureInfo requests
