CoverageInfo.getCoverage(envelope,dim) always uses the same CRS as sourceCRS and destCRS instead of using the original coverage CRS as destCRS
Key: GEOS-2243
URL: http://jira.codehaus.org/browse/GEOS-2243
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.0-RC3
Reporter: Daniele Romagnoli
Assignee: Andrea Aime
Fix For: 1.7.0
In "main" module, CoverageInfo.getCoverage method contains the following lines of code:
final CoordinateReferenceSystem sourceCRS = envelope.getCoordinateReferenceSystem();
final CoordinateReferenceSystem destCRS = envelope.getCoordinateReferenceSystem();
This result in useless future checks on CRS equality, when looking for a MathTransform between requested envelope's CRS and CoverageInfo's envelope's CRS.
The solution is to change the second line of code with:
final CoordinateReferenceSystem destCRS = coverageEnvelope.getCoordinateReferenceSystem();
