[Geoserver-devel] [jira] Created: (GEOS-2248) Generate BBOX for coverage editor forces the native CRS instead of the user defined one
                 Key: GEOS-2248
                 URL: http://jira.codehaus.org/browse/GEOS-2248
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.0-RC3
            Reporter: Gabriel Roldán
            Assignee: Alessio Fabiani
To reproduce:
from the release config, go edit the dem coverage.
in the coverage editor form set the user defined crs to EPSG:4326
- hit generage bbox: this forces the user defined crs back to the native one
if, by the other hand, you change the user defined crs and hit send/apply, then go back to edit the coverage, the user defined crs were applied. Hit generate bbox and it gets generated in the native crs instead of the user defined one
