Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-225
Here is an overview of the issue:
Key: GEOS-225
Summary: Generated SVG non conformant to the spec
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Versions:
1.2.2
Assignee: Chris Holmes
Reporter: Jean-Claude Moissinac
Created: Fri, 8 Oct 2004 5:11 PM
Updated: Fri, 8 Oct 2004 5:11 PM
Environment: Not relevant
Description:
I get the result from the sample installed by default.
With the request
http://localhost:8090/geoserver/wms?request=GetMap&layers=bc_roads&bbox=489153,5433000,529000,5460816&width=800&height=400&srs=EPSG:27354&styles=normal&Format=image/svg+xml
I get an SVG reply which is well displayed with IE and Adobe SVG Viewer.
But it doesn't display with some other viewers and the reason probably is a non-conformance.
The SVG spec says:
"In all cases, for compliance with the "Namespaces in XML" Recommendation [XML-NS], an SVG namespace declaration must be provided so that all SVG elements are identified as belonging to the SVG namespace. The following are possible ways to provide a namespace declaration. An xmlns attribute without a namespace prefix could be specified on an 'svg' element, which means that SVG is the default namespace for all elements within the scope of the element with the xmlns attribute:
and the generated SVG starts like this:
<?xml version="1.0" standalone="no"?>
<!DOCTYPE svg
PUBLIC "-//W3C//DTD SVG 20001102//EN"
"http://www.w3.org/TR/2000/CR-SVG-20001102/DTD/svg-20001102.dtd">
<svg
stroke="green"
fill="none"
stroke-width="0.001%"
width="800"
height="400"
viewBox="489153 5433000 39847 27816"
preserveAspectRatio="xMidYMid meet">
The xmlns attribute is missing and could be introduced like this:
<svg xmlns="http://www.w3.org/2000/svg"\.\.\.\.\.\.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
