[Geoserver-devel] [jira] Created: (GEOS-2250) Can only add one new coveragestore
                 Key: GEOS-2250
                 URL: http://jira.codehaus.org/browse/GEOS-2250
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.0-RC3
            Reporter: Arne Kepp
            Assignee: Justin Deoliveira
             Fix For: 1.7.0
(Sorry for not assigning to myself, got a lot to do the next couple of days, will give it a shot if I get close to that code)
The add coverage dialog is behaving strange:
1) Adding one coverage after restart or load works like a charm.
2) After you submit the first one, you are led back to the CoverageStore editor.
3) If you then hit the "new" button to add a second coverage store, the New dialog pops up correctly, but the id is an empty string, not the text input box you'd expect
