[Geoserver-devel] [jira] Created: (GEOS-2255) KML output does not validate
                 Key: GEOS-2255
                 URL: http://jira.codehaus.org/browse/GEOS-2255
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.7.0-RC3, 1.7.0 , 1.7.x
            Reporter: Arne Kepp
            Assignee: Arne Kepp
             Fix For: 1.7.1
         Attachments: kml_undo.diff
Originally committed in revisions 10315-10318 , pulled out again before 1.7.0 release.
Note that the Coordinatewriter causes problems for dwins' extrude code, the fixed Coordinatewriter for GeoTools, see http://jira.codehaus.org/browse/GEOT-2052 , should eliminate this problem.
Undo patch attached for reference.
