SRS handling not saved to info.xml
Key: GEOS-2259
URL: http://jira.codehaus.org/browse/GEOS-2259
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.7.0-RC3
Environment: Geoserver 1.7.0RC3, Tomcat 6.0, Windows 2003 server SP1
Reporter: Thijs Brentjens
Assignee: Andrea Aime
Priority: Minor
When setting the SRS handling for a featureType using the configuration UI, it is changed in a running Geoserver instance, but not saved to the info.xml. After a restart of the webapp (or the servlet container), SRS handling automatically drops back to the value 0.
