reprojection from epsg:
Key: GEOS-2275
URL: http://jira.codehaus.org/browse/GEOS-2275
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.0-RC3
Reporter: Justin Deoliveira
Assignee: Andrea Aime
Fix For: 1.7.1
Attachments: client.zip
Reprojecting the attached shapefile from its native projection (epsg:2154) to EPSG:4326 fails on 1.7.x with the following error:
09 Oct 14:22:22 WARN [renderer.shape] - Could not reproject the bounding boxes, proceeding in non reprojecting mode
java.lang.IllegalArgumentException: Argument "sourceCRS" should not be null.
at org.geotools.referencing.operation.AbstractCoordinateOperationFactory.ensureNonNull(AbstractCoordinateOperationFactory.java:732)
at org.geotools.referencing.operation.BufferedCoordinateOperationFactory.createOperation(BufferedCoordinateOperationFactory.java:247)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1361)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:265)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:335)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:416)
